Help Wanted: Harmonic Analysis of Transcriptions
13»
  • GadjoTheoGadjoTheo New
    Okay! So what makes F7 a passing chord is that it's the V to Bb, so you can play a Bb phrase over both the V and the I?
    Thanks, littlemark!
    Thanks again, Richter 4208!
    On bar 47, why can Stochelo sub that Eb7 for Ab6? I know they have several notes in common, and Eb7 is the V. Is there a reason that it works here?
  • edited August 2021 Posts: 561
    In m.47 he is outlining the Ab7 chord as you said then he is anticipating the D7 in the next bar. Because they are both dominant sounds/feelings.
    As I mentioned earlier, he's not really thinking about scales. He's thinking about chord shapes. Certainly not modes.
    GadjoTheo
    I think you misunderstood what I meant by passing chords. You thought the F7 was leading to the Bb. Which it does, but it's a bigger picture.
    The first 4 bars of the piece can all be g minor. You can get rid of the D7 (or not) but the F7 the Bb the Bdim are all just passing chords leading to the c minor in the next bar. They are harmonizing a walk up bass line. G A Bb B land on c minor!
    You could also substitute the Bb and Bdim for a G7. Which will lead you to the C minor.
    In m.67 over the f7 he is playing a gminor6 arpeggio. You are seeing it as a Bb6. Which it is. But Django is likely seeing a gmin6 for the whole bar.
    I hope that makes sense.
    Try not to always chase the chord changes. It will sound correct but not always like music ( as Denis says in his recent vid)
    GadjoTheo
    Thanks a ton, Littlemark! That's really helpful!
    littlemark
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.047055 / 1.186989]
