Sonora Gypsy Guitars - a visual model guide.
1235789
  • PJDPJD New
    Here is a vintage round hole gypsy guitar that has the same headstock and the clef tailpiece (which seems to be original to the guitar) as the Sonora's. It has 13 frets to the body, the scale is a bit smaller than the "Hono Sonora", if i measure correctly it is 682mm or at best 683mm. Interesting detail is the rosette, which is exactly the same as the busato grand modèle 1940 bouche ronde posted on the tremblayluthier.com website ( http://tremblayluthier.com/en/bus-gm-40-br.html ). I don't know if the guitar on the Tremblay Luthier website has got a Busato label, but there would maybe be a real Busato link if it does. 41cm at the lower bout, braceless heavily arched back and the top is arched as well.
  • PJDPJD New
  • PJDPJD New
    I'm laughing because my made-up 'Clef' nomenclature is getting used by the dealers now.
    I'm also laughing at the £1800 they're asking ;-)
    BucobillyshakesJangle_JamiePJD
  • PJDPJD New
    Did you finish restoring your new José Sanchez "Sonora"?
    AndyW
    Brilliant
    AndyW
    The posts on the new Schallers are too long so they meet in the middle on the super-narrow headstock. Thought about swapping in the the nice Delaruelles from my Rene Gerome, but I think I'll keep it original and shorten the Schaller posts on the belt sander for the Sanchez... Restoration 1, soon, is new tuners, a fret dress and clean & polish- Restoration 2 will be the fingerboard off, neck steam, carbon fibre truss rods & full refret - but not till 'later'. ( the neck's not really that bad )
  • PJDPJD New
    Do you only needs the yellow buttons for your tuners? There are some for sale on reverb i saw.. .
    AndyW
    @AndyW
    our tech always files down the shafts on the Schaller tuners. They’re always a bit too long for Gypsy guitars.
    AndyW
    I called it in my earlier response to this post a year ago. You quite literally created the taxonomy for these guitars!
    AndyW
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.020635 / 3.910759]
