String tensions
    edited April 2024 Posts: 163
    Hi 15 years later👋
    Re: “On average I found (for Gypsy Jazz strings) "10s" of various brands put a little over 20lbs down on an "average" top (this makes assumptions about the scale length, neck angle, bridge height & bombe height) and 11s of various brands put 6-9lbs more than that.”
    What’s the thinking then on bridge weight if the down-pressure is 20-30 pounds. Does a 5 or 10 gram difference in bridge weight (assuming properly fitted) make an audible difference if same bridge material stiffness if the down pressure is 20+ pounds? Asking because I’m building these days for a 25-28 bridge height w both ebony and Irw bridges and the bridge weight even with quite an under-scoop is high, as I’m trying to cut down on bridge weight (because “lighter is better” supposedly). But if down pressure is 9,000g and you shave off 5-10g, can you hear that? 🧐
    My current builds clock in around 1800g strung.
    *Noting: I can hear a difference btw an ebony and IRW bridge. I think it’s a stiffness/ transference material thing but possibly weight is a factor.
    Does Savarez publish string tensions (not downward force on the bridge) for their Argentine strings? Alternatively, what's the "Java string calculator" that @djangology mentions, and does it take into account the round cores, core diameters, copper winding, etc., peculiar to these strings?
    They do, which I found at https://www.savarez.com/argentine-boucle-1510 and https://www.savarez.com/argentine-boucle-1510mf
    I took screenshots incase the links rot after some years:
    GouchJSanta
    Wow, thank you!
    Paul
