G string dies quickly
    I use ball end Argie 11's on my US Hommage and have never had this problem. I think Enrique may be right about certain guitars.
  • pinkgarypinkgary ✭✭✭
    On the same guitar it happened with loop ends but not ball ends.
  • andreasandreas SwedenNew
    After playing for a while with a "lighter touch" I can confirm that this improves the life-span of the G-string considerably for me. Evidently, I was putting way too much pressure on the strings.
    /Andreas
    The G is a weak spot on these kinds of strings. I notice the same problems with classical guitar G strings as well.
    If your G is always wearing out oin the same spot perhaps you notice a gap in the windings), then the issue may be a frent crown problem, or a pparticularly sharp fret. Nothing that a periodic fret levelling wouldn't cure.
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.004652 / 1.051987]
