Manouche Guitar - Setup Recommendations?
  • Ryan RheaRyan Rhea Memphis, TN✭✭ '02 Lehmann Eclipse
    JMP wrote: »
    Al: thanks for the good advice. Can you provide a bit more detail regarding your warning: "don't over shim your bridge." What would generally constitute an acceptable level of shim use, and what would be too much?
    Not sure how much is too much, but on Sel/Mac style guitars I believe the tops are so thin (as compared to a traditional flattop) that too much shim can cause excessive downward pressure and could result in a cracked top.
    But Bob and Al would better be able to answer you on this than I. ;)
    RR
    Its more about sound and stability.
    I would not suggest shimming more than 3/64ths of an inch.
    I prefer no shims at all if possible.
    Shims are OK if they fit well.
    But you see guys shimming with anything , picks , match books.
    Ryan Rhea
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.004444 / 1.063103]
