Best key for "after you've gone"
Charles MeadowsCharles Meadows WV✭✭✭ ALD Original, Dupont MD50
in Welcome Posts: 432
It looks like Stochelo does it in C on the Rosenberg academy, Tcha plays in in Eb in DC music school. There's fabulous version by Adrian for Caravan guitars (the Park Montmartre demo) in F.
Any consensus on perhaps the one most likely to occur in jams?
«13
    For sure the key most likely is G
    To be clear, I believe Stochelo plays it in G, not in C. It starts with a C chord, but is actually in the key of G. Stuart, Wim, do you agree ?
    Anthony
    for the record, I prefer it in G, and have only Jammed with it in G.
    Your're right - it's G. Sorry.
  • If you can play it in G, you can play it in F. Tcha's chords from DC Music are well worth learning.
    if i'm not mistaken, django did a session in Rome that was in the key of C (starting on F)...
    Tcha does it in Bb so that it fits his vocal range
    The key the vocalist calls. (Ducks behind sofa and crawls out of room.)
    JonNonekevingcoxJazzaferriJim KaznoskyMarkA
    All the above. I like where the melody falls on the guitar in D. Usually at gigs and jams I'm at it'll be G, or sometimes Eb. It's a good one to work on transposing though, as it's pretty straight ahead with a few little twists for your brain to get around.
  • edited June 2015 Posts: 3,707
    Bb. Lays out nicely on sax and has a nice bluesy sound in that one, F is second fave.
    G is standard.
    I play it mostly in C (starts on F). . . as that's the key Eve sings it in. I like the idea of a most likely key, rather then a best key. . .
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.007274 / 1.255707]
