Fret buzzing
Guys I know you see this all the time but my Dell Arte is buzzing really bad on the high e and b strings mostly between the 10th and 14th frets. My action is 4mm!! I don't understand the combination of relatively high action and fret buzz. I am pretty on top of my room humidity and it has been level at 44%. Normally I would just take this into a luthier, we have some great ones in Denver, but I have a gig in Crestone this Saturday. Is this a fretboard relief issue that can fixed with truss rod adjustments. If so what way do I turn it? PLease help!
I have a back-up guitar for my gig, but I was hoping to take this one.
Thanks a lot guys!
  • edited September 2016 Posts: 3,707
    If you sight down the neck the answer is there.
    If you action is truly 4mm either something is very wrong with your guitar or the buzzing is not a fret buzz
  • Amendment: the action is 3.5mm. It feels like fret buzz because the the more i dig in, the louder the buzz
    It is possible for this to happen even with high action if a fret is higher than the previous one. You can check this by using a short and straight ruler - ideally it should lie flat across any group of 3 frets. If it "seesaws" on a fret somewhere in the problem area, then you have a high fret there and you may want to ask a luthier for a fret dressing.
    Another thing to check: sight down the neck and make sure there is not a "hump" where the neck joins the body, a lot of selmer copies get this dreaded hump at around the 14th fret.
  • richter4208richter4208 ✭✭✭
    Is this a new problem? Has the action changed suddenly or is this a problem that the guitar has always had? Are you traveling with the guitar right now?
    If there is a hump like @Wim Glenn suggests; invest in a humidifier if you don't have one already (you are best off getting one even if there is no hump!).
  • You guys are awesome. I have not been traveling with the guitar but I have noticed the action climbing for the last week. I think the season changing is get the air a little drier. I am still not sure why a drier guitar and higher action would contribute to the fret buzz, but either way I doubled down on my humidity overnight and the buzz is already noticeably better. I will check for the "hump" later tonight, but I definitely think the guitar is due for a set up and fret dressing.
  • nomadgtrnomadgtr Colorado Bumgarner, Marin, Holo, Barault
    Hey David,
    FWIW I've noticed some fret buzzing since the holiday weekend that seemed to coincide with a big drop in the relative humidity that occurred here in CO as the weather cleared up. I'm down to 10-12% humidity outside here during the day right now where we had been up in the 30-40% range previously. Just a guess but I think that's the problem you're experiencing.
    David Lawrence
  • Have you looked down the neck yet? If so what do you see
  • edited September 2016 Posts: 45
    So, I looked down the neck and for the life of me I can't see any humps or problems. The noise is also very rattly. I tapped on the top of the guitar and starting hearing a weird noise. I think there is a loose brace. The one by the sound hole. Looks like you where right @jazzaferri. Something is more seriously wrong with my guitar.
    Weird noise could also be a loose truss rod.
    wim
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.005438 Seconds Memory Usage: 1.000168 Megabytes
