Modifications/upgrades to add bass to a Gypsy Jazz guitar?
Hi, I have owned my Manouche Guitars Latcho Drom for almost a year now, and I love it, however I would like to add more bass to its overall sound. I do not wish to take away from the highs or mids, but I would just like a little more bass response. I've tried Galli silk and steel Gsl 11's and Galli V27's in hopes the silk would add more bass but instead they just killed the guitars volume in every department. I've read that wooden resonators tend to add bass, is that would I am looking for? Thanks for the help!
    have you tried heavier strings?
    edited November 2017 Posts: 1,900
    As the owner of a guitar which used to have an interior wooden resonator before I had it removed, I would advise against this idea.
    Your guitar may not be like my custom-made model made by a prominent Canadian luthier, but what it did to mine was virtually eliminate the midrange.
    Admittedly, the soundbox did make the bass seem more bassy and the treble more trebly. But the overall sound was not really one you'd wish for.
    And even though the soundbox was made of super-light wood, it still added more weight to the guitar than felt comfortable.
    What was especially @#$% annoying that the interior soundbox was all my idea, not the luthier's! But somehow in the course of making the guitar, he forgot to put it in.
    He actually had it all finished and was raving about the great sound.
    He sent some JPG pictures of it to me, and I immediately said, "Wait! You forgot the interior soundbox!"
    So he graciously took the guitar back to the shop, where he had to take the back off in order to add the soundbox... which added an extra month or so to my delivery time.
    And then several years later, I had to pay a second local luthier to remove it!
    And, you guessed it, it turned out the first luthier was absolutely correct, the guitar did sound great in its original incarnation.
    What's the old saying? "A fool learns from his mistakes, while a wise man learns from the mistakes of others."
    So I urge you to be a wise man.
    Unlike yours truly.
    Will
    PS I, too, was disappointed by S & S strings. Didn't add much bass, but somehow deadened the sound. I've still got a bunch of sets kicking around here that I don't know what to do with.
    BucoEduardo
  • Try the Lenzer Fisoma S&S 11's
  • EduardoEduardo Valparaiso, IndianaNew Manouche Guitars Latcho Drom
    Interesting you say that the resonator ruined your sound. I probably have read more negative reviews about them than positive ones. The silk strings truly did deaden the sound. Do you have any recommendations for strings to add a bit of bass? I have used D'addario gypsy jazz strings and Savarez strings, both having an .11 high E
    I know this is a drastic measure but I would consider adding a soundport on the upper bout.
    Not sure how you would really accomplish an actual modification but be careful about adding bass as you might end up with a lot of unwanted overtones (ringing, 'wetness') which you will not like.
  • Joshl-mJoshl-m New
    Lately, I am really fascinated by how much the bridge contributes to the overall sound of the guitar.Is your Bridge Rosewood or Ebony? You could try using a bridge of a different material. Not nearly as drastic as adding a sound port and a lot easier to come back from if you don't like the results.
    The La Bella strings have a thicker gauge:
    http://www.labella.com/products/gjm-be-gypsy-jazz-silk-steel-medium/
    They even have a 12-56 set. However they're silk and steel which you may not like.
    On my guitar adding a soundport made it sort of bigger sounding but not really add more bass. Bridges do change sound as well. Try a pick with a very rounded tip. But none of these will give you bass that a large bodied Martin dreadnought has, keep that in mind. And your guitar will not change it's basic sound signature. But you might be able to get something to your satisfaction with enough experimentation.
    Eduardo
    This might be a little extreme, but here's one way you could add bass:
    morriconelewischang88BucoEduardoPetrov
    Soundports actually raise the lowest resonance of the guitar -- the "boom" when you thump the top (e.g., typically G on an oval hole). So although it might end up sounding deeper to the player's ear (because you hear sound directly from the port), there's less bass out in front for the listeners.
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.004578 / 1.062508]
