Galli V027 S & S Low E doesn't go all the way in the tailpiece?
HI all,
I searched but didn't find anything on this exactly. I feel like a dork asking, but I don't recall this from before, many years back.
I installed a set of V027's and am immediately gonzo for them. However, the Low E ball end won't insert fully through the tailpiece hole. I almost exclusively always used loop ends, but do recall a set or two of ball ends, and don't remember this.
I don't imagine that's right? Is the ball supposed to go all the way up against the post, or will time work it in?
Thanks much.
-Paul
pas encore, j'erre toujours.
«13
    Had exact problem with the gallis myself the other day! Lucky I found a loop end in my bag. I thought the problem was with the hole in the post not being big enough but now I know that the problem is with the strings themselves? Apparently?
    Passacaglia
    Ha! Timing. The holes are small, and I can't see any way for that low E to go in. I can't imagine it's a problem with the string, and thought it would be weird if the Altamira holes are somehow non-standard small. So, I'm stumped. Thank god I'm playing alone, because if I showed up at a jam, I imagine I'd truly look like a noob. Playing like one is enough, thanks.?
    -Paul
    edited May 2020 Posts: 337
    Oh wait, mine is an Altamira as well...hmmm
    perhaps someone else will chime in
    Passacaglia
  • NewcastleBudNewcastleBud Erstwhile✭✭✭✭
    If the string itself can pass through the post, but it jams up at the red yarn (or whatever it is), you should be able to force it through with no major repercussions.
    Just my dos centavos.
    PassacagliaBuco
    I think, therefore I am......I think.
    In my experience, the low E would not fit, the A string did fit but stopped at the yarn, and you’re right a good hard pull brought it all the way through.
    Passacaglia
    Yup,
    I've used V027's for quite some time, and once in a great while, you get that exuberantly wound E or A string.
    Passacaglia
    Thanks guys. I guess that lone low E is just going to have to look like a stray, then. Just didn't know if somehow that weakened the string. The A actually flew home on tuning it a few times.
    Have to say....MAN do I love the sound with these strings.
    mac63000vanmalmsteenBuco
    -Paul
    A few times I even had to file down the end of the winding after removing the silk wrapping, think it was with LaBella which has beefier low E. Strings are fun to experiment with.
    Passacaglia
    It's not for the PITA that makes me want loops. Really. It's only the cool look. Really.
    -Paul
    Can you pop the little metal cylindrical piece out of the end of the string and just use it like a loop end???
Software: Kryptronic eCommerce, Copyright 1999-2024 Kryptronic, Inc. Exec Time: 0.016455 Seconds Memory Usage: 0.998734 Megabytes
