Thumb Position
    Ok, I am trying a little less thumb. Looking at Figure 1 in the book helps me to see what you are talking about. I am now modeling my left had position on that. The problem now is that within 5 minutes of trying to get it right, the area around my first finger and thumb hurts. Is this a sign that I am doing it wrong, or is it that I am just unpracticed?
    My guess is that it will feel better overtime...but make sure not to strain anything!
    dlloyd wrote:
    I had some difficulty with the G7, but it's coming a bit easier now.
    The Cm7 with the thumb barring the G and C, on the other hand...
    That one's a beauty....you can also play it with just the G, and mute the C note on the A string.
  • Chris PetersonChris Peterson Santa Monica, CANew
    The help you guys gave last night was very helpful. Today I was able to play for about 20 minutes in thumb position. Every 5 minutes or so I did some major hand stretching exercises to relieve some minor pain, and that seemed to help out a lot. I imagine that I should be able to get to where I can play for a decent amount of time relatively quickly as long as I keep doing my stretches.
    Work on the <A HREF="http://www.petersonmusic.com/wiki">Gypsy Jazz Fake Book</A>.No finale experience necessary.
    If I want to play a C6/9 at the 2nd fret (332233), would you use your thumb on the E and the A string or would you rather not use your thumb at all and grab them with your middle finger ?
    - JG
    That is always played with a one finger double stop on E and A strings. The middle finger is used.
  • noizenoize Netherlands✭✭✭
    How does one exactly accomplish this double stop with the thumb?
    Do you reach over or not?
    With every position I tried which sounded like my thumb is at least touching the A string, the neck just cuts in the side of my thumb, and it hurts like hell.
    It doesn't sound too bright either.
    Note that I have no problem at all using my thumb one the E string.
    Some kind of picture would be nice.
    I just reach over and grab both strings with the pad of my thumb.
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.004311 / 1.063202]
