My guitar is exploding!
13»
    John - I saw that one at Lowe's this morning. It's definitely on my short list.
    Both Gitanes are now out of the "sensory deprivation humidity chamber," and performed well at rehearsal this morning. Still a little but of buzzing. I ended up having the shim the bridge on my Jorgenson, and adjusted the truss rod some. Hopefully some vigorous playing will cause it to settle down
    @Tele295 should be fine I know you gotta feel better already. If my humidifier dries up while I'm away, or not watching as closely as I should. I've taken a small fan and a dampened microfiber Towel clipped to it. I guess you might call it a homemade Humidifier. It gets humidity in the room quickly, watch for the towel to dry and repeat.
    Gets old quick, but it works!
    pick on
    Pickitjohn
    Huh, fan and a towel. Sounds pretty awesome, I'll try that.
    Microfiber are incredible!
    You could dry off after a shower with one, they hold a lot of moisture for their size. I also have three in my guitar case to cushion & fill the voids around the guitar.
    pick on
    Pickitjohn
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.005649 Seconds Memory Usage: 1.010307 Megabytes
