1947 transcriptions
    PapsPier wrote: »
    For TuxGuitar, you need to install first the Java DevelopmentKit (it is an extended version of Java if I understood correctly) and then install TuxGuitar and it should run perfectly.
    Here is the link Java Development Kit
    I've installed JDK 8 but still no dice. The program appears to open, but then closes again immediately. Several other people on the user reviews / download page are reporting the same issue of the program not opening on mac:
    https://tuxguitar.en.softonic.com/mac/comments
    If you run it on Mac with no problems, it might be that you are still back on a very old version of macOS? I'm on High Sierra here.
    Wim Glenn wrote: »
    Ditto.
  • PapsPierPapsPier ✭✭
    I had this issue but JDK solved it. Ill check my version tomorrow but I m pretty sure it is Sierra too (I just bought the imac before I was on PC)
    Did you re install TuxGuitar after installing JDK? I am not sure but it might change. I just know that this trick worked for me and other people on the french forum without doing any crazy code changes
    Solved: it was old version of tux guitar causing issue. The one on first google result is bad:
    ^ This is v1.2 and doesn't work on recent macOS.
    The third google result is a sourceforge link to a v1.4, and that one does work:
    https://sourceforge.net/projects/tuxguitar/
    Yay! I'm happy you found the solution. I hope you ll find my transcriptions Worth the time you spent...
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.006079 / 1.052887]
