Forum Encoding Issues
MichaelHorowitzMichaelHorowitz SeattleAdministrator
in Welcome Posts: 6,221
This discussion was created from comments split from: This and that (nothing important).
  • Brad HermanBrad Herman San Francisco, CANew JWC Modele Jazz, Stankevicius Alena, Alexander Polyakov Selmer #6
    The software that powers this forum has a feature that automatically links the word issues to the github issues page in case you're talking about issues with the forum itself, so you can file it for the developers to look at. As an engineer, I get why they did this, but also think it's kind of an asinine assumption to make.
    lewischang88BucowimBillDaCostaWilliams
    3. Whenever the word "issues" is uttered in a discussion thread, why is it always highlighted in yellow
    Always wondered about that too =)
    The software that powers this forum is garbage. For example, if you put in some weird character, it completely chops off the rest of your message. e.g. I will write a PILE OF POO character and then another sentence below it, but you won't see anything after and including the unicode character
    edited January 2018 Posts: 6,221
    @Brad Herman Sorry about that. There was a plugin doing that which I fixed.
    Wim Glenn wrote: »
    @Wim Glenn I haven't experienced this problem. Give me a more specific example that I can replicate and maybe I can figure out what the problem is. There's a lot of encoding settings which could possibly be causing this issue.
    test
    richter4208lewischang88
    before
    edited January 2018 Posts: 1,600
    ^ so, that's what happens when I post the text, exactly as shown from here:
    https://hastebin.com/feyosoqero.txt into the "Leave a Comment" box and click "Post Comment". It's happened enough times now that I know not to use any weird characters, for fear of losing what I've written in the post. I use chrome browser, and it happens on both macOS and Linux. Hope this helps!
    edit: this issue seems related https://github.com/vanilla/vanilla/issues/4309#issuecomment-268053661
    @Wim Glenn thanks.....if you enter the Unicode for the emoji it seems to work
    &#1w28169;
    But I see what you’re saying about just cut and pasting the image. There’s some sort of scrubbing or encoding issue which could be the result of a number of plugins and settings i’ll look into it
    Thanks for your work Michael!
    MichaelHorowitz
    Ahh nice! I figured it was either a setting enabled by default by the developers, or a plugin. Glad it was the latter as it's much easier to fix.
    Matteo
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.005789 Seconds Memory Usage: 1.009209 Megabytes
