Reverse La Pompe
135678
  • RipRip New
    If each beat is a triplet, then it's the first 2 beats of that triplet. Now do that on the first beat and the 3rd beat of the 4 beat measure. The first strike of the pick happens on the downbeat.
  • RipRip New
    btw, you need to come to dfnw, i wanna jam with you!
  • stuologystuology New
    edited August 2023 Posts: 196
    I think I know what Rip means, just moving whatever you do for the 1st and 3rd beats (however you want to describe it) to the 2 and 4. I can't say I've heard any gypsy jazzers play like this, it sounds a little bit like ska, maybe the gypsy ska crossover has finally been discovered?
    Ripbbwood_98Buco
    It sounds normal to me.
    But maybe the lead is getting in the way.
    Rip
    I listened to it briefly too and didn't hear anything off, but then I didn't go back or analyze it any further.
    I suspect there was just a bit of rhythmic displacement similar to that famous Harry Connick 5/4 video that is all over youtube. If I'm not fully aware of where the downbeat of measure one is, I might just hear it as if it is on the 1 and 3. My brain just shifts it over.
    Rip
    @stuology and @Rip Aw yeah, now that is a thought! Django-Ska; Skaology . . . hmmm.
    Rip
  • RipRip New
    edited August 2023 Posts: 360
    I was definitely overplaying so I covered it up to much, but here is a picture of what i was doing. This convo can only happen on djangobooks!
    Edit - play air guitar with the recording using your picking hand
    DoubleWhiskyBuco
    So true 🤣
    billyshakes
    I see what you are saying. But I don't hear it.
    What you drew in theory doesn't swing. That looks more like a straight Latin thing.
    I think you are just swinging harder than you normally do.
    Maybe you are normally a laid-back swing and this is just pushing a bit.
    Wait I think I got it. Did you record the rhythm and then lead?
    If so, maybe you just "corrected" your rhythm by Displacing the beat by a triplet eighth note.
    Possible?
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.016975 / 3.886459]
